560 int. power steering
poorboy88
New User
I have a internationa 560 with power steering, the steering went fo the left to the stop but to the right only hALF WAY SO i FORCED IT TO GO RIGHT ALL THE WAY AND NOW IT WONT WORK AT ALL --ANY HELP???
Mine acted similar. What I did was take the steering knuckle off and remove the cover plate for the worm gear shaft and put more tension on the centering spring. You might also check the dog that goes from the unit on the bottom of the worm gear to make sure the it is still stradling the part in the worm gear that controls the flow of fluid to the direction that the tractor is being turned. If you remove the left frame rail it will make the job a lot easier.
