460 positive or negative ground?
NolanJae
I have a dumb questions. I have a 460 gasser with a 12 volt battery. let my frined use it a he replaced a couple of bad battery cables. He also turned the battery around. Is the 460 a negative ground system or a positive ground? If he put the cables on wrong will it still work?? and if so what will it damage?
Negative from factory, generator from factory. With a generator, the only thing that "might" wear out faster is the voltage regulator, if changed to positive ground. If converted to alternator, and battery is changed to positive ground the alternator is ruined.
