Distributor question
Anonymous-0
Is their and differance between a 6 volt and a
12 distributor on a farmall A. I know the coils
are.I see a lot of 6 volt distributors for sale.
Could I just put a 12 volt coil on a 6 volt distributor?
yes you can just add a 12 volt coil however, you may or may not need to add a resistor before the coil depending on the coil (inernall or externally resisted, if exteranally resisted you will need one)
Andrew
Distributors are like switches. They are not voltage sensitive at all. 6volt distributors just came off of a 6volt tractor, but the same distributor could have been found on a 12 volt tractor. Unless the voltage was in the range that would break down the insulation, or jump the point gap, they work.
Do be concerned with the centrifugal advance. A distributor from a cub will fit on a M, but the advance limits, and advance curve will be different. This includes springs and the mechanical stop on the max advance. Jim
