Oilpump drive gear farmall 350
Klein Rot
Hi,
For a friend of mine I am looking for an oilpump drive gear for a Farmall 350. He has the oilpump with the gear on the photo, but it don't fit because the gear theet are wrong, it will not fit in the distributer drive gears. Who can help him with a good one.
Left looks like a gear for a 350 diesel tractor. No go on gas. If the pump is also a diesel it won't have a ignition drive opening. On a 350 gasoline the gear from a ignition drive housing without a live pump will work. Shouldn't be hard to find a gear from a H or SH. Take gear off shaft and install on the pump shaft.
