Filter Question (HYD)
I have a 706 Farmall, I changed the Hydraulic filter and when I started the tractor up I had no brakes or steering. When I let the clutch out there was a little sound under the platform every little bit. I just kept pushing the clutch in and letting it out every so often. The sound under the plat form would not happen when the clutch was pushed in. After a few minutes of going forward and back with the tractor, the steering and brakes started to work. Before the steering started working, the steering wheel would turn very hard, but not turn the wheels. Did I get air in the system?
Thanks as always for your comments.
Yes you "got air".Check the fluid level,if full ad 5 more gallons of fluid.Common problem with Farmalls.
