Air Filter Gage
I believe I have a Air Filter gage? There is a Red and Green Dot in the gage. What is the correct way for this gage to be hooked up? The needle always stays over the Red Dot? Tractor Running or not running? I see two wires on the Air Duct by the filter that probably signal the gage. Is there another line in the system? I have a new filter and no obstructions in the line. Thanks
You must have the 310 german.I had the same problem.finally removed the sender,gauge and whole system.havent missed it.continue to regulary service the air clearer,youll be just fine
