Utility 300 torque amplifier
Anonymous-0
Looking for help to rebuild my amplifier for my utility 300. I understand replacing the spring and roller system with a Form Sprag bearing is the better way to go.
Does anyone know part numbers and the procedures needed to make this happen? If I'm not headed in the right direction, please let me know. (does not have belt pulley)
I also replaced the main clutch awhile ago, but I think it has way to much spring pressure as it takes alot to push the clutch pedal down. I would like someone to let me know if I need to replace the springs or if there is a hydrulic assist availabe as a add-on.
A sprag and hd ramp is a better way to go if you are using the tractor to push snow or a heavy loader system. I have the parts on hand if you choose to go that route. My email is open.
