I have a SMTA that's been rebuilt ,However L.P. head was pretty bad. Machine shop welded cracks,did guides and valves but It seems I am still getting slight oil from a valve guide in one cylinder and little water in other cyl. At High or low idle I get slight miss.AT full load runs fine. Compression is at 170. I am thinking of putting one of Dennys Carbs 55,000 volt coil on it. Do you think it would help plug fire better?Can points and condenser handle that hot coil? Engine has 4 1/8 flat top pistons with 450 l.p. head.A.L.3116 plugs. I am trying to make it to a show in couple weeks wanting it to run decent until I can tear down again.
Any thoughts, advise,criticisms, welcomed. Tony
