I have a 1949 Super A which recently had a cracked block which is not repairable. The engine was a C113 engine which cracked. I was able to find a replacement C123 block whose casting number was 354898R1 and the serial number on the engine was CM136118 which appears to have come on the later Super A, Super C's, and some other models. I plan to order a Basic Engine Overhaul Kit from this website with part number BEKH1159-LCB to replace the "guts" of the block (Crankshaft is being ground and bearings will be acquired from machine shop, Also valve train is in good working order). I would just like to verify that this is the correct Engine Overhaul Kit for my block's casting and serial numbers. Also it appears that only stepped head pistons are available for this block on the website. Any additional concerns with stepped head pistons as the previous pistons were flat?Any opinions would be highly appreciated.
