Glo Shift Tachometer issues
pafarmall
Thought I would try asking on here: I tried installing my GloShift digital tachometer/shift light on my Farmall MTA and it work fine until I mount it to the tractor. I was mounting it to the stud that comes up thru the hood where you normally put a wing nut. When you tighten it down the guage goes completely blank. Any ideas would be great. Thanks in advance.
Either or.
Either the tach failed (I assume the voltage and ground connections/polarity are correct.
Or the wires pulled loose.
Positive ground?? Jim
