Antique tractor estimated value
I have a McCormick Farmall 100 tractor approximately 50+ years old. Does anyone have an idea of its value? It has been under a shelter but is not in great condition.
If you have a photo you could post that would be most helpful. So much depends on Engine and internal conditions and the condition of the tires.
Tires alone can swing the value of an antique tractor by $1000 dollars one way or the other.
Unfortunately the basic value is based on what it weighs at a scrap yard and goes up from there. If there is other equipment that goes with it or is mounted on the tractor that creates more value. Or if a machine has certain optional equipment.
Post a photo if you can.
The tractor itself may be worth $2000 in working condition. If it has a fast hitch, plow, disc, cultivators and side dresser, I can see it going for $3000. In the south east, Farmall 140s in working condition with implements generally will sell for $4500. I have seen a few unrestored 140s in very nice condition with implements sell for $6000.
SF
A lot of factors come into play when pricing a tractor. If it runs that is a big thing. Tires also play a big part since if you have to have all new tires they can cost $500 plus. How good or bad the sheet metal is also plays a big part. With what little you have said it could be a $300 scrap iron tractor up to a good running in its work cloths $1500 machine. When asking what a tractor is worth the mre info you can give the better an idea of what it is worth can be figured out
