Mr. Roper
New User
My daughters C has a motor that is lockedup and I need to find one to replace it with. What should I look for and Where and what is a good price ?????
Thanks for all the help and comments.
Roper, Do you no why it's locked up? can it be fixed? Unless you buy a rebuilt engine, because of the age anything you buy may need rebuilding anyway. oldiron29
You can get new sleeves pistons and bearings for less than 400 kit and you will have a new engine. You will have a very hard time to get a running engine for that tractor as they just arent available insetad you overhaul the one you have. Where are you located.
Did the motor just "lock up" or has it been sitting for a long time. If it happened suddenly, then loosen the starter bolts just to make sure that the starter isn't locked in the forward position. This happens a lot with these old Farmalls. There may be nothing wrong with the engine.
we bought the tractor for her a couple of years ago and it has been sitting with diesel and atfluid in the plug holes, but it is still locked. previous owner said that he was pumping water with a pto pump and it just locked up, maybe not a big deal until he left it sitting for who knows how long with the plugs out. Not good, but atleast the hood was still on. He also stated that it was recently overhauled before all of this happened. Thanks and any help is great.
