IH560 Hydraulic Pressure
Anyone know what the pressure should be at the rear outlets on a Farmall 560? I have plugged a gauge in to the outlets and from the check valve side, 1000 psi, the other side has 1400. I suspect I am not shifting the spool all the way in the hydro touch valve.
Thanks
holding the lever so it dont go to neutral, pressure should be 1200-1500 psi. at 900-1200 the lever should go to neutral without holding it.
Thanks, the pressures were taken with the lever held and not letting it return to neutral.
Since the one side is good on pressure, I suspect that the spool is not being shifted all the way when I move the lever to the opposite side. I'll check the linkage etc.
