My 460 hydraulics work fine when the tractor is cold. After an hour of use my feet get hot and you can tell the hydraulic oil is getting too hot. My fast hitch then starts to drop and raise then drop and raise just a little bit. Then it gets harder and harder to lift implements with the hydraulics,like a wheel harrow. Again when I first start off everything works great and the hydraulics will lift anything, but then after an hour or so it just stops working and the foot plate gets really hot. Ideas? Anything worth trying before replacing the pump? Ive checked the valves and theres no rust in them, I am thinking maybe the adjustment for the fast hitch?
