1206 mfd question
756puller
i had the left hand drive shaft pinned and welded up at the local machine shop about six months ago, put it on the disc today made a round with the mfd engaged, and then the mfd quit working like i broke the shaft again, what could be going wrong since it seems like i keep breaking drive shafts?
are you talking about the axle or drive shaft,if you welded a broken axle and didn't heat treat it will more often than not break again.
On pavement, I agree the continuous stress of mismatched tires would be a killer, in a field it should be no worse than loading the tractor until it spins out. Not recommended, but not an axle/drive breaker.
