Hydraulics on the Farmall 240 are getting too hot. I recently had a problem with the teledepth valve sticking and causing the pump seal to blow out. Puts the hydraulic fluid into the crankcase. Pump has been repaired, and I replaced the teledepth valve body with a hydratouch valve. The way it is set up now, there are two hydratouch valve bodies on the left side of center, and a block with no fittings then another hydratouch valve with remotes on the right side. I assume that I am not getting enough flow to keep it cool, or running too high of pressure. Any thoughts?
-Horsepoor
-Horsepoor
