Super A pressure plate
Goodman
I had to do some repair work on the fingers on my pressure plate. Can any one tell me at what position I should put them in other than just all the same? Height from the clutch side or something?
Thanks
For the work it takes to get to it, if you already had to work on I'd put a reman in it. To answer your question I don't know the measurement. What and why did it need to have?
Not for sure. Is is a Rockford? Is there a number on the cover? If somebody has an I&T manual the info should be in there. I'm not finding one.
On a Cub with a Rockford clutch and PP, it's 1 1/4" from the tip of a finger to the top surface of the PP. No clue if it's the same on an SA. Good luck. CCL
Here is a Picture. I believe it was a Rockford, but it has 6 springs, so whichever one that is.
I looked in the service manuals but no information on what I needed here.
Contact face of the pressure plate should be 2-3/8" from the contact faces of the fingers, and 27/32" from the base of the cover.
Are the bolts pictured on the fingers the shipping bolts that need to be removed? Or do they stay on there for height adjustment? Also, which direction does the clutch plate go in?
