I wanted to install the live hydraulics on the H and leave as many things original as possible. I changed out the front cover and gears to one from a 300, along with the pump.
A 5 gallon hydraulic tank from Northern fits nicely in where the belt pulley was. I am fabricating a plate to cover that and mount the tank to.
I mounted a cross dual hydraulic valve under the seat. The outlets of the valve are piped directly to the pioneer couplers. I reach under the front of the seat to operate.
The lift all is intact.
I need to mill an outlet block for the pump, put hoses on and it is done.
