I had to replace the head gasket on my Farmall M this summer. Under the valve cover is a 1/4 inch tube that runs from the front of the engine to the back. Not sure what this is or what it does. There was a small hole in it and lots of gunk on the tube and on the valve cover. Went to purchase a replacement tube and found out the part is no longer available. Local International dealer mentioned bronzing the hole as an option. As I was cleaning the tube it looked like the hole may have been there for a reason. I did bronze it so the hole is covered. Can someone tell me what the tube does and is there suppose to be a hole in it?
