Bleeding the hydraulics
Most times that happens the line is full of air. By working the hydraulic levers it should get rid of air.
First and most important, do you have enough hydraulic oil in the tank. Hydraulic systems are normally 'self bleeding'. You should be able to fix the problem by simply moving the controls from to position, hold it for a few seconds and move the control to the opposite position. That should get rid of the air.
