OK guys here's a full update for you on what's been done.
1. cleaned couple times.
2. electrical, replaced light & key switch (everything works) and plan to replace wiring harness and battery leads, spark plugs, wires etc.
3. Misc mechanical... brake work, replaced seals, etc.
4. new hyd hoses... 2pt and remote.
5. all new emblems, seat, steering wheel
6. gauges are good, replaced one that was bad.
7. reset valves
regarding painting process..
-cleaned tractor repeatedly.
-removed all sheet metal and fenders as they are at my painters shop getting stripped and "worked" on.
-removing all wiring & guages prior to painting.
-wheels to be removed from tractor prior to painting also.
So far so good... LOTS of time on this but it's coming along well.
Seems like we keep finding more, but in the end it will be worth it.
7. reset valves
