IH 460 rear axle oil leaking around spline/washer
unfkr
New User
Has any one had an issue with the trans/hyd fluid leaking out around the spline/washer in the center of the rear wheel?? If so whats the fix? the seal that is there just seals the hub OD as near as I can tell,I am not seeing any fluids at that end at all just the outside center of the wheel, I have a Utility so no sliding axles or wheels. Thanks in advance ,Carl in Edes Falls,Me
AHAH, Thank you Owen, I see it on the diagram now, I will get one in there forthwith. Thanks again,Carl
