Super H gear swap question
Zachary Hoyt
I found that the gears in my 53 SH parts machine are in very good shape, and I have pulled them out to put in my H. I was reading through the archives and saw that I should also take the SH reverse idler as well, so I will do that. My question is should I also swap the differentials while I am in there or are they the same. If I don't need to swap I'd rather leave them, since it will entail quite a bit more work. Thanks very much for any advice.
Zach
The output shaft and pinion should be left in the H. Unless you feel competant to mesh the ring and pinion, with tooth pattern and backlash constraints, leave it alone. Jim
