3588 power steering problems
kidd1954
i have a 3588 that i am having problems steering. It doesn,t turn as fast as it used to and sometimes it stops and jerks. Just wondering if someone has had this problem before and could help. I"ve taken apart the block over the pivot and the valve moves freely. I have also taken the relief valve out and it moves freely.
Its just a thought but have you checked your hinge pins? I ve seen the bushings get bad and make it hard to steer, Basicly its binding. Id check that if it were me then go from there. Good luck
