300 Hydraulic Pump
David G
Can you tell me the bolt diameter and thread for the hydraulic
manifold that bolts onto the bottom of the pump?
Thanks
This is not sarcasm, but just find bolts that fit, I do that all the time. Not too long, not too short, easy for me to say because I have a supply of bolts. My guess is coarse thread, but I am not sure of that. Also the length of the factory bolts is not necesarily the same length of the ones commonly sold today -- that is not important. If you have to have the exact size it may (or may not) be given in the parts book or on www.caseih.com.
The pump is mounted, and I have tried a couple of different bolts, just dont want to screw threads up.
You won't hurt the threads unless you try to force the bolt in. Try the bolts before you try to mount the tubes. Sometimes those tubes are hard to get aligned with the front and rear, but I haven't worked on a 300.
Good, I looked at the CaseIH site, but there were several bolts listed and I could not tell for sure which bolts went where.
