Bringing a 560 farmall back to life, after about ten years outside. Cleaned out fuel tank and overhauled the carb. Runs too rich at idle, not terrible, but noticable. Runs best with idle needle fully closed. Soaked carb for a week, blew everything out good...had it apart 2-3 times with no luck. Otherwise, it runs great, and responds to throttle well. Heat riser is working, and it will idle smoothly, and very slow...just rich.
It still has the earky double venturi,and it was stuck so tightly I was unable to remove it. Anything I needed to clean behind it?
