John_in_WI
New User
I'm looking at purchasing an IH 340. I don't know
the year off hand. It's gas and equipped with an
IH 2000 loader. (I know it's a little big for the
tractor.) I've done a bit of part time farming
and operated or worked on more than one tractor,
but I've never owned one or really needed to know
much more than basic mechanics about one. Now
that I'm looking at buying one, I'm hoping some
one with experience can help me figure out whether
this is a normal, run of the mill 340 that needs a
little work, or if it's a basket case I should
walk away from.
That said, the main issue with this tractor, (I
apologize I don't know the correct term) the
steering box, that sits under the cowl directly in
front of the operator, is loose. When you turn
the steering wheel, it will jog around (in an
opposite direction it's attempting to drive the
tie rod/drag link) until it appears that the bolts
holding it down run out of room, then the front
wheels will turn. I believe that the bolts
holding this box down had been tightened up a year
ago, but after a little use, it's loosened up
again (It's loose enough that with the engine off,
and no power steering, you can move it around by
manipulating the steering wheel.)
Is this a common problem? Should there be dowel
pins of some kind that maybe sheared off over the
years? Is this a detrimental defect or something
I could get fixed by a competent farm mechanic?
I'm a machinist by trade, and my common sense
tells me even if castings are cracked and blind
pins are broken, I could repair something like
this - given time. But I need a working tractor
and I don't have the time to tear one down right
now, at least not until I finish a couple other
projects, so the best case for me would be to buy
this tractor rather cheaply, and have a mechanic
make the repairs needed to put it to work.
It is the ideal tractor for my use, which is
general hobby farm utility stuff, moving snow,
moving a little dirt, pulling logs out of the
woods, knocking down weeds etc. It's coming with
some actual Quick Hitch implements which are in
great shape, a brush hog, back blade, sickle bar,
and the loader and hydraulics appear in excellent
condition (no or very little leaking, strong
positive movements).
There are some more minor issues that I don't mind
fixing over time, like the seat being pretty much
destroyed, brake pads (or shoes?), and it's still
6 volt. But I think I can get it for a song, if
it would take $1,000 or $1500 for a mechanic to
really fix the steering issue and tune it up a bit
(runs and starts very well, but the throttle tends
to run away, think there's a governor issue?) it
would be worth it in my opinion.
Thanks.
walk away from.
Thanks.
