What's a Fair Price For an IH 300 utility?
WI Dave
Here are all the details I have on it: tin is in good condition, looks to have faded, original paint, four good tires, the ad says it runs good, it has a FEL, and comes with a bush-hog mower. It's about 10 miles from me. He's asking $3000 OBO. What would be a fair price range, based on the info I've given? Thanks.
That sounds like a good price to me. If it hasn't been all cobbled up I would go for it. Heck offer $2500 and see what happens. Look for welds, hydraulic problems, clutch condition, torque status , etc.
FEL so does it have power steering??? t does not you will find you can only drive it which ever way the tires are turned because the steering system on the 300U is bad unless it has power steering
The others are correct. A loader can beat the steering to death, if it steers and is not loose, and the axle is not welded to be repaired, the 2500 to 3000 range is OK. Make sure the TA works under load by starting out in 5thTA from stopped Full throttle. Jim
Hi, Dave.
$3,000 or $3,300 (I don't remember which) is what I paid two years ago for an IH350U with TA, power steering, a front end loader, and NO bush hog. I've been very happy with the tractor and very satisfied with the deal.
As always with the utility series, check for steering slop and TA (if so equipped) slip. These are the Utilities' Achilles' heels.
If it doesn't have power steering, I would seriously consider passing on it. I don't think you'd be happy with a front end loader and manual steeing.
Mark W. in MI
I have a deal for you! Two 300U, FH,PS,good tires. the problem is both need to have the tanks removed and cleaned. $3200.00 for the pair. The owner died and they need to leave my place. North MO
