Farmall M/MCH Upper Bolster
Hey guys! I see in the parts book that an MV uses different pivot shaft bushings in the upper bolster from just a regular M. My question is, will an MCH use the same as the MV or just the plain M style bushings? Need to replace the picot shaft bushings on my MCH to tighten up the steering and would like to have the new parts on hand before tearing it apart. Thanks for your help! Also, are the front wheel bearings for my 7.50-20 going to be the same as those for a 7.50-16 single front tire? Thanks again!!
Since the weight pushes up on the upper bolster shaft like a M I would think both the same. If you have the one piece hub I think the only change between the 16 inch one piece hub front and the 20 inch was the fork.
