Rear Weights
nh8260
Just wondering what size rear weight bolts i need to put them on my farmall super a? i figure one side will need to be a little longer then the other?
(quoted from post at 23:19:44 09/20/11) Just wondering what size rear weight bolts i need to put them on my farmall super a? i figure one side will need to be a little longer then the other?
I put A/SA/B type weights on my 240U and cut all-thread to length. Nutted and lock washered on both sides of the wheel, slid the weights on the all-thread and then a flat washer, lock washer and nut on the outside. Has not worked lose yet. Weight is relieved on the back side to easily clear the double nut.
The online parts diagrams at CNH (if the Super A is on there) should have the bolt specs. I know they are there for the Hs and Ms.
