farmall H wiring
SLH
I have a new fuse holder for my H . My question is the fuse holder has 2 leads one that comes out the end and one that is made on the fuse holder which wire goes on the end lead and which wire goes on the bottom lead. THANKS
It doesn't make any difference since it is going to have power on either end as long as the fuse has not blown. I do have a question on an H voltage regulator. The tractor is still on a 6 volt positive ground. I found a new old stock regulator which has no markings other than the number 1409 on the bottom and Positve next to the lead going to the generator on the bottome of the regulator. I was told this meant it was a positive ground but do not want to mess up something else if it is not. Any help would be appreciated.
