200 Brake Oil Seal
LMack
Both of the oil seals (Both Sides) need to be replaced behind the brakes. What am I getting into when I do this? Yes I am talking about behind the brakes because the disk are wet with oil. Is it a big job and do I need any special equipment? What parts should I have before I open it up? Same questions about the oil seals at the ends of the rear axles?
It is a pretty easy job, you need a manual and alittle know how but its pretty easy. Youll need to order Brake Pinion seals.
Andrew
Thanks. Problem was that the CIH parts site did not list a seal or I did not see it on my first trip there. I will look again.
