C Blue Ribbon Service Manual
TMatt
I'm looking for an IH Blue Ribbon Service Manual for a Farmall C. I found one for a Super C on this site, but was wondering if anybody knew where I could find one for a regular C or are they close enough it won't matter?
Thanks
(quoted from post at 13:18:41 10/26/11) I'm looking for an IH Blue Ribbon Service Manual for a Farmall C. I found one for a Super C on this site, but was wondering if anybody knew where I could find one for a regular C or are they close enough it won't matter?
Thanks
Probably not enough difference to matter, but binder books dot com will have reprints available.
Check the numbers on the one you found. The only one that's been available (for YEARS) for the 113/123 motors has been the one for the 113s in the A/B series. All the instructions are good, it's only the cylinder and ring dimensions that might be off for a 123 or a 113 with larger sleeves after a rebuild.
If the numbers cross and the book you've found is the A/B book I refer to, or if they don't and someone has found and reproduced a book for the SuperC, the differences are minor.
Here"s the description for the one that I found on this site...
"Super C Service Manual 370 Pages (Part No: IH-S-SUPER C) $76.95"
Looks like it is different from the A/B manual, that one shows to be only 65 pages.
I"m doing some transmission work on my C so I was hoping to find a little more in depth info than the IT manual has.
Thanks
Just did a search on this site on the part# and on "370" and I'm not coming up with anything. Where are you looking?
370 pages would be waaayyy too much for the manual you are looking for. I don't think the parts catalog is that many pages.
I found that under "Tractor Manuals" up on the top left side of the page, from there I went to IH Farmall and then typed C in the search box.
