farmall 130 cultivator frames
johnald
I recently purchased a farmall 130 and noticed the other day that the cultivator frames appear to be incorrect. The square stock that connects into the tractor frame drops down and the right side lift arm is on the inside of the steering wheel shaft, not the outside. My main question is will switching to a straight square stock correct the problem or does it look like my cultivator frames are mismatched. I tried to upload pictures but it wouldn't let me. Thanks for any help you can give.
Do they look like this.....
If so, you have a set meant for a High-Crop tractor.
This is what a non High-Crop should look like....
You can switch out the bar and see if it works for you, or sell them as they are to someone with a HC Super-A through 140.
I would think they would be worth a little more as they are compared to a standard set.
yeah, they are the high crop. Thanks for clearing that up. I'll probably just use them until i can find someone that wants to swap. Thanks for the help.
