cub clutch update
Anonymous-0
Split the47 cubagain,removed the clutch assy.Turned the disc around so tne hub was on the engine side.Put it back together,adjusted the fingers to 1 1/4 inch,back together and adjusted free play.Works fine this time. Got the job down to 1hour and 45 min. thanks for the tip on adjusting the fingers befor putting it back toghther.
I wish I would have thought of that. Put it together and the clutch wouldn't release. Someone told me to adjust it thru the hole in the bottom. It worked.
