Ireland.29
still having power / pulling problems with Kerosene H, i'm hoping some of you guys might know what could be wrong? I should probably say what I've checked already .
Correct (new) spark plugs fitted.
Same problem occurs whether running on straight petrol or kero.
Had head worked and piston rings replaced last year.
had carb apart and cleaned it.
the problem is it wont pull in 5th gear if there is even slight hill, and when shifting from 4th 5th on dead level ground you need to ride the clutch to get going and even still takes ages to build up speed.
any ideas? Could it be a governor problem?
