Ignition wiring for 560
RAM560
New User
Does anyone have a ignition wiring diagram for a 560 or know how a ballest resister is wired in ? Thanks, 560 Farmer
The ballast is wired in series with the ignition Key and the coil. (if pos ground, the neg of coil)
there may be a wire from the Starter solenoid that is marked "I" this goes to the distributor side of the coil to bypass the resistor when starting. Jim
This has the diagram
