Weight of H engine
Senator
Getting ready to pull the engine (1943 Farmall H). Hoping my engine stand is enough to hold it. What's the engine weigh?
Thanks,
Ron
The bare block is around 180# according to the old bathroom scale I keep in the shed for weighing such things. The head is just shy of 70 with valves but no rockers or valve cover. Crankshaft must be around 40-50, I think, flywheel must be that much again. Water pump/fan is around 15, camshaft must be similar or a bit more, so I would guess around 500 pounds total depending on what has been removed from your engine. Governor and rods and pistons and timing cover I cannot recall what they were last time I weighed them. I hope that helps.
Zach
i have one i weghted to get shipping cost it is long block no manifold or carb no mag did have flywheel and clutch head and rockers and cover 550 lbs
