Need 1066 Hydro input shaft
Anonymous-0
I twisted the hydro input shaft into right at the tranny housing. Where can I find one and how big of a job to put it in. Are there any new shafts available or would it have to be salvage.Good tractor and I want to fix it. The plate that the shaft is splined into that is bolted to the flywheel is messed up also.
A good used might be hard to find, they changed the splines from 11 to 13 on all this size hydro, the parts are same from the first 826 hydro, 966 hydro, 1026, 1066 & 100 Hydro, 186, just match splines on drive disc & shaft.
just call up a hydro shop they should be able to give you a direction to go, i just replaced one in my 966 a month ago
herrs machine in kansas, i got mine at eismanns supply in madison nebraska, and also get yourself a service manual it walks you thru how to replace it without tearing everything apart
