NAPA # for 1950 M fan belt
Take the old belt in. I bought one and had to go back about 4 times till we got it right. Would've saved some work had I just used the old one.
GATES belts/hoses did have at one time...and I presume still have...a pretty good catalog on agricultural/industrial equipment. More than likely, it won't be on the computer...need to get the "old guy" at NAPA/O'Reileys to help you. Taking the old belt with you helps also.
Rick...who used to work in parts once upon-a-time, many, many years ago.
I'll guarantee you that if he is that lazy to look up and help,,I'll be going some where else to buy my stuff,,and let locals know about this p@$$ ant...
Not sure about the NAPA number, but my Farmall M with Delco Remy generator takes a Bosch 13A0955 belt. I bought Bosch because that is what the local Autobarn had in stock. Seems to work OK.
SadFarmall
Be prepared the next time you go to NAPA. Look up the IH part # then go to NAPA web site and find the box for searching a part #. Put the IH # in and check the interchange box. Or go to agriculture tractors or heavy equipment and try to find the application for the tractor. Or just take the IH part # to the store and all the counter person has to do is hit a few buttons on the cumputer, don't even need to know what a tractor is.
I'm dumber than a sled track on a computer, so if I can do it you can.
Regular duty belt from crank to coolant pump and fan, IH # 16131DA = NAPA-NBH 2528454. Heavy duty belt IH # 277448R1 = NAPA- NBH 2530467. Heavy duty listed as around 34 bucks at a store 10 miles from me. Other one cheaper.
Or just order it on-line using the IH part number. You'll have it in about 2 days, and most likely at a lower price.
This site has them for $14 and change. Why not support YT?
Go to "Tractor Parts" far left-top under Marketplace
(quoted from post at 14:04:29 01/12/12) NBH 2530467
Yup, and they want $33.99 for it. Not at my local store, but it is "at the warehouse" which means I could get it the following day.
