Telker
New User
I've heard people say how easy it is to drop a v-8 engine in a H farmall. I've been thinking about trying it. Are there plans to do this available and what is needed to accomplish this
Any help would be appreciated.
Thanks
Jerry
[email protected]
(quoted from post at 13:18:22 02/10/12) I've heard people say how easy it is to drop a v-8 engine in a H farmall. I've been thinking about trying it. Are there plans to do this available and what is needed to accomplish this
Thanks
Jerry
[email protected]
I've seen a few installed in Ms. The H is 2" narrower. Probably not quite as easy.
Plans are for sissies or them what aint smart enough to improvise. It will be different if you use a Ford or Chevy orDodge or International truck motor so plans are almost unheard of. It is a fit and manufacture as you go thing. And easy it is NOT,
Some of these modified tractors can be very neat, and some are just cut and hack jobs. There is a guy on You-Tube with a Chrysler Hemi in an F-20. There was a guy locally here on Craigs List with a small block Chevy in a F-20. I have seen big and small block Chevs in Hs and Ms. I once saw a Massy 44 pull that had a 396 Chev in it, and one that had a 302 Ford. Also a Massey 30 with a Chevette motor. I personally think these are cool and interesting, but many people are very turned off by the whole idea of it. I say do what makes it fun for you !
Right on Mike, F12,F20,F30 about the easiest thing to put an odd ball engine in; two frame rails to put motor mounts on and then something to couple the clutch outout to the tranny.
If you DO install one,just be careful with the tractor.
The original engines usually will not be putting out near the torq/HP of what you might be installing???
If you would hook onto a weight sled,pull a plow,Something SOLID,ect? and really hook the tires hard,You can SHATTER those rear ends in these things! take it easy on em! ;)
A buddy and I just finished puttin a 7.3IDI diesel outta a ford truck into an M. It was alot of work, but now the M has 200horse and does about 35MPH on the road. Gotta be careful with it though.
My dad and the neighbor have been trying to put an IH V8 into an M for the last 6 years. That means two things: one it is not exactly easy and two, it clearly is not a priority project-he doesn't even know what he'll ever use the thing for. Like the others said, I would expect the H to be tougher as its a smaller tractor.
NOT to "pee" on everyones parade here,but ther V8 isnt even really nesessary here.Most of the time this is done either because someone had a bad original motor and has a "free/cheap" V8 sitting around,or just for "looks".I have to admit,a 426 Hemi with chrome "zoomies" looks cool!!! I am NOT trying to put this idea down! I like "different" too!
But you can take the stock 4 cylinders and get them up around 500 cu in ,if you want to?Big puller friend of mine built one and you couldnt tell it from a stock 264 cube original! ;)If i haul off and start in on my new "salvage yard" find,that is what I will do!
I've seen an M at local pulls a time or two that used a stock block and a turbo with alky. I don't know how many cubes he was running. He ran it in unlimited class and it sounded really unique at RPM compared with the v-8's!
Saw an H a few years back with a GM 2.8 V6 in it that looked pretty nice. Of course, my first thought was that a 2.8 was pretty "gutless"...but when I read that the builder had put an S-10 4-speed manual transmission, locked into 2nd gear, in the torque tube, it made perfect sense.
The engine turned a bit more than twice as many RPM's as the original H engine. Second gear in the old S-10 4-speed tranny is approximately a 2:1 gear reduction. SO...the S-10 tranny serves to reduce ground speed to about what it would've been with the original H engine, PLUS it's used for torque multiplication, so that the 2.8 isn't nearly so gutless as it would have been.
So it's a win-win all around.
BUT I'm convinced that if you're gonna do a V-8, you should step up to an M.
I would say as long as there was a certain amount of rear tire "slippage" while pulling,the rear axle/gears will survive,I guess???
I would bet if these Ms with these big engines had their rear wheels really stuck in a ditch,I bet it would bust something in that rear end?
I am just "fishing" for people with knowledge of how strong that Final drive really is ???? ;)
There's a local guy who built one using a 454 (fairly mild by most standards) and a sm465 4 speed as an intermediate transmission. It does have plenty of tire slippage but I don't think anything has broken on it, at least not yet. It's based on a SM.
The best sounding one I've seen had a well tuned 383. Many of the "hot rod" v-8 types are not tuned that well and you can hear them lean out half way down the track. This 383 sounded strong the whole way, probably a true 350 to 400 horse motor based on my guessing and the heads he was using.
