I have a 706 gas that i bought. Tractor has sat for over 10 years and engine was froze up. Just rebuilt engine and it wont start. New pistons, sleeves, reconditioned head. Cranks and tries to fire but wont run. After cranking, gas just pours out of carb. Installed new carb-same thing. New carb does not have solenoid on it. Adjusted needle out that is in place of solenoid. Plugs are not getting wet. Installed new manifold-same thing. New points, condenser, cap, rotor, plugs, wires, coil, and resistor. 160-165 psi compression on all cylinders. Good vacuum at carb when cranking. Disassembled front cover to verify timing. ok. Distributor is timed properly to oil pump. Removed head to verify pistons are in properly. They are. Valves are all adjusted properly. I am a mechanic by trade and this is very frustrating. We have to be overlooking something very simple. Any help on this would be great.
Thanks.
Thanks.
