C and SuperC wide front
plow hand
Is there any difference between a C and SC wide
front are they interchangeable w/o modification? < I'm changing C narrow to wide..Thanks
These guys are correct in saying C and SC wide fronts will interchange with no modifications at all. They will swap easily. But just an FYI, there is a difference in the C &amp; SC wide fronts and thats in the tie rod ends and steering arms. They went to an automotive ball joint type tie rod end/steering arm at some point in production on the SC wide fronts-not sure if it was right from the start or not. I don`t think any C`s came with the later style tie rods. Anyways, just sayin`.
