Got my auxiliary valve parts
W.Brehm
Well my journy to Miles, Iowa payed off. Haskin Tractor had the two parts I needed 358470R1 7 358471R1. There were two Super MTA's and four Super M's and all have seized auxiliary valves. I got all the pipe fittings and pipe, seized auxiliary valve, and mounting piece and the washer for $40. I hopeing that I can unseized the valve.
FYI if anyone looking for the mounting parts for the auxiliary valve on a MTA he has a tractor sitting there.
Pull the three bolts out of the top cover and soak with
penitrating oil or diesel fuel then use a wood dow rod and
tap out the piston from bottom of valve. I got mine unseized
this way cleaned it up and it works great.
A little advise on that nut that sits on the VERY top of the valve (The one that holds the detent spring.)I believe alot of them get water in them right at this point.(You could see where water had made it's way into mine right here when I got it!)I put a 1/4" nylon washer under the little steel washer to seal it.
You say he has other aux valves in bad shape for sale?
(quoted from post at 16:15:48 02/12/12) A little advise on that nut that sits on the VERY top of the valve (The one that holds the detent spring.)I believe alot of them get water in them right at this point.(You could see where water had made it's way into mine right here when I got it!)I put a 1/4" nylon washer under the little steel washer to seal it.
Everyone that is still on a tractor are all seized. I have all plumbing pieces, so I just throw the valve I have sitting here and try to save the one I just got.
(quoted from post at 18:12:17 02/12/12) Can I get that valve you are tossing?
E mail me
I'm going to try to unseize that valve, if I have no luck I'll give you a hollar. I have a good valve I'm going install on the tractor.
