I have the bolster tore apart on my 43 H. While its apart I was going to tighten up the steering a bit. Top bushing on pivot shaft is pretty tight, but the bottom is loose. Before I spend 70 bucks on a new bushing, I want to see how much wear I've got on the shaft. Anyone know what the shaft should mic where it rotates in the bottom bushing? I've got a bit of taper, it's 2.570" top and 2.561" bottom.
Also so far the only place I've found to get a new bushing is from Case/IH (that's the 70 bucks). Any other outlets you know of?
Thanks, Ron
Thanks, Ron
