(quoted from post at 11:56:10 02/27/12) Ive got a 39 H soaking now with no luck,Ive broke a dozen of old tractors loose but mostly taping on top of the pistons,Im to the point if soaking with anything will lossen them,they werent stuck good in the first place.Here on the east coast I beleive the humitity is a lot worst than most place
jimmy
(quoted from post at 13:18:46 02/27/12)
Of course there is always the option of pulling the motor, removing the crank, and then use a BIG press to remove the pistons and sleeves as a unit. You can then break the sleeve and peel it away from the piston so you can remove the piston pin and salvage the connecting rods. New sleeves, pistons and a few other things and you've got a brand new motor.
(quoted from post at 16:06:22 02/27/12) mmack,Burn it out! This method will get the job done in one afternoon. Follow my direction here.
1..Remove all, hood gas-tank, nose cowel, and radiator, Head and all wiring harness. Pan, oilpump, and rod caps. Have the tractor where you can roll it outside, CLEAR AREA OF GAS CANs, GREASE RAGS AND ALL FLAMMABLE THINGS!
tractor is now outside.
2..fill the cylinder with the most volume with Diesel add a splash of Gas, Set it on fire. Go get a cup of coffee and enjoy till the fire has burnt itself out. Take a block and a 4 lb sledge and drive the piston out from the bottom.
3.. repeat #2 on the next 3 pistons with the most volume. As you work your way down to the cylinders with the least volume the #of burning will go up to generate enough heat to pop the rust around the rings.
This method will allow you to at least inspect the piston and sleeve to see if they are salvageable.
***The first two usually go pretty quick the last 2 take a little longer.
***If motor is on a engine stand you can rotate the engine over for easier driving of the block.
Hope this helps!
Later,
John A.
(quoted from post at 19:21:11 02/28/12) A guy around here that restores a lot of tractors got something made he could screw into the spark plug hole and hook a hydraulic hose from another tractor to and put pressure on that way.
(quoted from post at 11:21:11 02/28/12) A guy around here that restores a lot of tractors got something made he could screw into the spark plug hole and hook a hydraulic hose from another tractor to and put pressure on that way.
