Cub slow to lift implements
Is anyone elses cub slow to lift a harrow? or Cultivators? How fast should it lift? mine is a little jumpy and wont pick it up all the way with weights on the harrow...if i drive forward it seems to creep back up. any ideas?
When was the last time you cleaned the filter and is the linkage to the system ajusted correct. Put a pressure guage and check how much pressure the pump is putting out
Have you checked the hydraulic fluid level? Low fluid will do that. If It"s low and you fill it check it again soon, like the next day. If It"s low again you need to figure out whats happening.
Dave
I HAD THE SAME PROBLEM AND HAD TO BUY A HYDRAULIC KIT , ABOUT 30 DOLLARS, AND IT TOOK CARE OF YOUR PROBLEM. THE SMALL SPRINGS GOT WEAK ON THE VALVES.
