ih504
New User
how much is a Farmall 504 gas with 800 hrs, wfe,3ph new rear tires and rims, good original paint worth?
(quoted from post at 00:33:04 03/04/12) how much is a Farmall 504 gas with 800 hrs, wfe,3ph new rear tires and rims, good original paint worth?
Are you sure it`s only 800 hours on it ? Only reason I`m asking is why does it have new rear tires with that low of hours on the tractor. I have a Farmall 404 with 1300 hours on it and the rear are in real good shape yet, probably 85-90 % rubber on it yet. That being said, if everything is there,original, and in working condition with nice sheet metal and with the WFE, I`d venture around 4500 - 5500. My 2 cents worth
I suppose after 50 years the original tires and rims might've gone bad, especially if they sat without air for a long time. Only 800 hours does sound kind of low though, I'd suspect a disconnected hour meter unless the tractor is in really good shape. Around here maybe $2000-3000 depending on condition; buyers are going to assume it has higher hours, needs a TA, etc.
I guess my price was based on the assumption that the 800 hours is accurate. If that was the case, the TA shouldn`t be an issue, but you`re right- buyer beware, you never know how it was used. This "what`s it worth" guessing is hard W/O pictures ,or better yet, seeing in person. A real 800 hour tractor is worth more to me than your average 504.
