MW live pump fluid
Did a little searching and never really found much of an answer. Should I be running universal hydraulic fluid or 30wt non-detergent oil?
Pump is going to be running a Koyker SuperK loader if that makes any difference. Thanks!
I know what he meant, I worked for a company with 500+ trucks with live hyd systems and that is what they ran, where the temp is between -30 to 90+
I think it only matters if you are going to use the hydraulics with equipment that will be connected to other tractors. You should use a compatible fluid in that case so it will not cause damage to the other tractors.
I used 30 wt in the M I just sold, I doubt if the pump cares. As stated if you are also attaching someone elses implements, the other person might care.
