Hydraulic fittings
We always used "iron" pipe fittings for hydraulics, both pressure and return, since I was a kid.
With these Chinese fittings though, I don't trust them. There is definitely less material there and they just feel cheap.
Instead, I use cheap Chinese hydraulic fittings for pressure these days. They may not be as good as the USA-made fittings from 20 years ago, but at least they're meant for hydraulics.
I actually bought USA made black pipe fittings at the local Ace Hardware. I was pleasantly surprised.
Dan
(quoted from post at 07:37:41 03/07/12) Yes we do it all the time. Use them on the pressure side also.
Gary
With the old 800# systems on Hs, Ms, etc., black pipe might be okay on the pressure side, but on the modern 3000# and higher systems I wouldn't do it. Return side, have at it, no problem.
